Wall height ?
BrentMiller
By direct manipulation of a wall poly line (Home Designer Pro Only or Chief Premier, not Suite or Architectural).
By programming a wall to be a "Solid Railing" then you control its height by the Newels and Baluster Height input box (Chief Premier, Home Designer Pro, Suite and Architectural.)
You mainly control wall height via a Room Specification Dialog - Finished Ceiling Height input box (the ceiling height controls the height of the ceiling and secondarily the height of the walls that form a room. This is all explained in your Reference Manual in detail.
