Jakeiscrazy Posted June 4, 2021 Share Posted June 4, 2021 Hey all, as the title implies I have created these two dormers and connected them with interior walls but from reason I can't select just the dormer area because the walls don't fully connect. What am I doing wrong? TIA! ETA I am using Architectural When I attempt to drag it over I get this: Jake's File.plan Link to comment Share on other sites More sharing options...
Jakeiscrazy Posted June 5, 2021 Author Share Posted June 5, 2021 Ha if only I could, when I attempt to connect them (by dragging them together) I get the error above (Cannot build walls because existing walls are in the way. I am in Home Designer Architectural, I'll add it to my sig. Link to comment Share on other sites More sharing options...
Jakeiscrazy Posted June 5, 2021 Author Share Posted June 5, 2021 So I got one of the dormers to work by running the wall on the inside. The other still doesn't work. Here is a little video that will maybe throw a little light on the problem. Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 5, 2021 Share Posted June 5, 2021 Maybe this is what you are trying to do? Link to comment Share on other sites More sharing options...
Jakeiscrazy Posted June 5, 2021 Author Share Posted June 5, 2021 19 minutes ago, Jo_Ann said: Maybe this is what you are trying to do? That's a great suggestion but unfortunately did not work. It creates a weird space that doesn't need to be there and isn't present in the front. Here is the back. And the front New file attached for reference. Jake's File2.plan Link to comment Share on other sites More sharing options...
Solution Jo_Ann Posted June 5, 2021 Solution Share Posted June 5, 2021 So, do the same thing that you did up front. The reason it didn't work for you in your video, is because you have to keep a small gap between the dormer wall, and the interior wall. Link to comment Share on other sites More sharing options...
Jakeiscrazy Posted June 5, 2021 Author Share Posted June 5, 2021 That did the trick! Thank you Jo Ann! You are awesome! Link to comment Share on other sites More sharing options...
