stanmason Posted June 1, 2021 Share Posted June 1, 2021 I am using Home Designer Pro 2021, Build 22.3.0.55x64. I am trying to add insulation in a section detail. I drew a rectangle, opened the fill Style but insulation is not shown as an option. Am I doing something wrong? How do I add insulation? Link to comment Share on other sites More sharing options...
solver Posted June 1, 2021 Share Posted June 1, 2021 Search the Home Designer website for insulation. Always a good place to start when you have a question. Link to comment Share on other sites More sharing options...
stanmason Posted June 1, 2021 Author Share Posted June 1, 2021 I have already looked there. It does not seem possible except to draw it manually using CAD tools, very painful. Link to comment Share on other sites More sharing options...
solver Posted June 1, 2021 Share Posted June 1, 2021 The answer is there. Have you searched Help? The answer is also there. Link to comment Share on other sites More sharing options...
DianeQ Posted February 4 Share Posted February 4 stanmason, did you ever find the answer? Link to comment Share on other sites More sharing options...
solver Posted February 5 Share Posted February 5 4 hours ago, DianeQ said: stanmason, did you ever find the answer? On 6/1/2021 at 12:53 PM, solver said: Search the Home Designer website for insulation. Always a good place to start when you have a question. On 6/1/2021 at 1:28 PM, solver said: The answer is there. Have you searched Help? The answer is also there. Link to comment Share on other sites More sharing options...
SKorte Posted February 11 Share Posted February 11 Wow, help that’s not much help. I search the website and it gives me this thread. Ummm. Found the Reference Manual so will try that. Link to comment Share on other sites More sharing options...
ChiefTylerL Posted February 11 Share Posted February 11 @DianeQ and @SKorte, there is an "Insulation" tool available in Home Designer Pro. This tool is essentially a box polyline with an insulation fill. You can use this tool in plan views or elevation views. It can be found in Home Designer Pro by going to CAD> Boxes> Insulation I hope this helps! Link to comment Share on other sites More sharing options...
