Doug0976 Posted April 15, 2021 Share Posted April 15, 2021 I am currently using Home Designer Pro 2021. I need to cut 2 1/2' of the width of house, I thinking of doing it down the center from the front door to rear door ( which would make my living room smaller) , is there a way to splice the 2 1/2' from the center or section of house only? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 15, 2021 Share Posted April 15, 2021 Use the Edit - Edit Area Area All Floors command along with the Transform-Replicate tool command to make the precise move of all objects and then clean up the mess it creates. Were I you, I would make a copy of your plan as insurance of a total chaos using unfamiliar tools for the first time. DJP Link to comment Share on other sites More sharing options...
