Create Shadow Moldings
esanchez
Does anyone have any techniques or suggestions on how to create shadow moldings in Home Designer Pro? Is it possible to create a custom profile for moldings and is it possible to create a profile that sits within the drywall section. See example below on shadow molding:
Not in Home Designer.
You could use a Custom Backsplash set to Cut Finish Layers, but you would need to place one for each wall, and the corners won't look correct. Use a Wall Covering to simulate a base with a different material
