View exterior and interior wall layers?
EnBee99
2 minutes ago, EnBee99 said:
Is it possible to see the exterior and interior wall layers (not just the main layer) in the plan view?
The default is to see all wall layers. Have you changed something?
Maybe post an image showing the problem.
Thanks!  Below is a screen clip that - I can only see the main layer of the wall and not the exterior layer (brick) and the interior layer (drywall).  The dimension lines seem to be correct.  I'm using Home Designer Pro 2021.
