Adding interior wall to garage plans makes that "room" rise up
ThirtyWest
Hi all, I'm using HomeDesigner 8.
I have a garage I'm designing--a detached.
If I draw an internal wall at one end of the room (to make storage spaces etc), the floor height of the walls lift up compared to the other end of the garage.  It even raised a side entry door that was on that room too. If i delete the interior wall, it falls back to the grass.
Suggestions?
2021 newGarage.plan
I did.  the first two were garages.  the additionally made room was just called entry (for lack of an idea).
I thought there was a potential issue with the foundation with garage, but I hadn't built foundations yet.  this is just to work on shapes and layout--not for construction plans..
it's a standalone structure.
did you open the file attachment?  it's just an interior wall dividing the room somewhat.  it doesn't matter which name/type i give them.  the wall raises that new room off the terrain.  if i delete the wall, it falls back down.
