ChiefWhataChuck Posted March 8, 2021 Share Posted March 8, 2021 Started in print settings: drawing sheet set-up: custom then made a size called "Arch-D (24" x 36") put the size in the width/height and left setting at 1" = 1" All looks good when I select it as my new saved layout but, when I go to export as a PDF I get a black sheet at 24" x 36" ... select any other paper size other than my new Arch-D (24" x 36") and everything shows up ? What am I missing here? Chuck HD Pro 20 Link to comment Share on other sites More sharing options...
Rookie65 Posted March 8, 2021 Share Posted March 8, 2021 I don't think 24x36 D size paper printing ability showed up until HD Pro 2021 Link to comment Share on other sites More sharing options...
ChiefWhataChuck Posted March 9, 2021 Author Share Posted March 9, 2021 Rookie65 you are correct. I set it up properly in drawing sheet and layout but, the HD-Pro 2020 does not allow print/PDF generation beyond 18" x 24". Tech support confirmed. Upgraded to HD Pro2021 and it worked! Link to comment Share on other sites More sharing options...
sierrahm Posted April 5, 2022 Share Posted April 5, 2022 ChiefWhataChuck - Can you share a template ARCH-D layout if you've already scaled the ARCH-C default border with text information? I've attached the layout I see when I change the drawing sheet setup size to ARCH-D. ARCH-C_to_ARCH-D.layout Link to comment Share on other sites More sharing options...
sierrahm Posted April 9, 2022 Share Posted April 9, 2022 NVM. There's a page on this (https://www.homedesignersoftware.com/support/article/KB-01829/resizing-a-layout-title-block-and-border.html) and it's not all that difficult. See attached for a resized title block and border at ARCH-D size. ARCH-D.layout 1 Link to comment Share on other sites More sharing options...
SoloRider Posted September 26, 2024 Share Posted September 26, 2024 Thanks a ton for that layout, this was totally tripping me up as well. One small addition I'd make is that I wanted this to be the default layout when I do New Layout so after noticing the paths listed in https://www.homedesignersoftware.com/support/article/KB-01866/resetting-template-files.html, I realized that replacing the "Profile.layout" in the templates directory gave me this Arch D layout as the default. Link to comment Share on other sites More sharing options...
