2' oc framing starting from end of wall
BldWhtfld
Using Home Designer Pro 2021, I am trying to create 24" O.C. framing starting from the end of a double stud wall using automatic framing.  The framing is correct in all studs except the ends of the wall.   See image attached example of 24' wall.
Is there a setting to tell the software to start the stud spacing from the end of the wall or is this something that needs to be done manually?
Thank you in advance for any help/suggestions.
Kathy
