MyMtnHome Posted January 31, 2021 Share Posted January 31, 2021 A design that I am working on uses various sizes of horizontal steel components. I have imported the items from Sketchup. Is there a way to apply a specific fill pattern to each size and/or type of steel component so I can easily visually differentiate between the items when I am in Plan View. Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2021 Share Posted January 31, 2021 If such items have a "Dialog Box", look and see if that Dialog Box has a "Fill Tab". If it does you should be able to use the Fill Tab of the object's to apply a fill, if no fill tab then no object fill is then possible. Take a look please. DJP Link to comment Share on other sites More sharing options...
MyMtnHome Posted January 31, 2021 Author Share Posted January 31, 2021 Thanks Link to comment Share on other sites More sharing options...
