Kgoodwin243 Posted January 26, 2021 Share Posted January 26, 2021 I've built a front porch with 6x6 posts to beam above to support the roof structure, spacing 10', for a 30' wide porch, netting 4 posts. When I attempt to build stairs down from the deck, it automatically places full-height posts at the top of the stairs, and throws off the post placements accordingly. I want the stair railing to terminate into a short post at the deck that does not interfere with the full-height porch posts. I've tried manually placing posts, but the railing and stairs don't interact with them. Any ideas? Link to comment Share on other sites More sharing options...
solver Posted January 27, 2021 Share Posted January 27, 2021 Link to comment Share on other sites More sharing options...
Kgoodwin243 Posted January 27, 2021 Author Share Posted January 27, 2021 Perfect, thanks a ton! Link to comment Share on other sites More sharing options...
solver Posted January 27, 2021 Share Posted January 27, 2021 This gap is caused by the default post/newel spacing. Increasing it to more than the length of the railing should eliminate it. Otherwise, looks good. Link to comment Share on other sites More sharing options...
Kgoodwin243 Posted January 27, 2021 Author Share Posted January 27, 2021 Ah yes, thanks for that, I fixed that as well. Now, maybe I should have asked this first... but I'm trying to get the 6x6 posts to continue downward and land on a footing. I don't necessarily need the 3d to model exactly to my specs (first pic), but I do want it to show the 6x6s bearing on footings underneath, at least when I do a front elevation view. I plan to have the 6x6s continuous from the footing to the beam above for the roof trusses, and hang the triple 2x12 deck beam between the posts using a concealed-flange triple joist hanger, then hang the floor joists to the back of it. If there is a way to have it do that, I can't figure it out (maybe it's possible on Chief but not HDPro?) I plan to rent the full Chief version to finalize and generate plans so seeing it done on Chief would still be of great help. Considering that I will have deck framing details broken out separately on the plans... I would be happy with applying the band-aid of just upping the joist sizes to 11 1/4" (just to show front beam depth on the front perspective view), and just clicking and dragging the 6x6 downward to a concrete footing I place independently underneath, but I can't select and manipulate the individual posts themselves (again, maybe with Chief I can)? Link to comment Share on other sites More sharing options...
solver Posted January 27, 2021 Share Posted January 27, 2021 15 minutes ago, Kgoodwin243 said: I plan to have the 6x6s continuous from the footing to the beam above for the roof trusses, and hang the triple 2x12 deck beam between the posts using a concealed-flange triple joist hanger, then hang the floor joists to the back of it. All done manually. Post generated as part of a railing cannot be manually manipulated. Link to comment Share on other sites More sharing options...
