TheOtherMike Posted January 22, 2021 Share Posted January 22, 2021 Ola, is HD Pro compatible with third party rendering software? If so, any suggestions? thanks, Mike Link to comment Share on other sites More sharing options...
PH_Decor_Design Posted January 22, 2021 Share Posted January 22, 2021 We export the DWG file and re-create the 3D view in a third party software such as 3Ds Max to do a render Link to comment Share on other sites More sharing options...
TheOtherMike Posted January 23, 2021 Author Share Posted January 23, 2021 Thanks PHDD, will have a look Mike 1 Link to comment Share on other sites More sharing options...
Robborito Posted January 25, 2021 Share Posted January 25, 2021 So what's wrong with the export to 'Collada' DAE file? File\Export\3D Collada model (DAE) Using all you creative input used in HDPro exporting instead of conversion back from a DWG export? (If you had an abundance of time on hand you could then export form DAE Collada to SKP Sketchup.) IMO - HDPro produces very good 'physically based' images if time is spent with available settings. Chief Architect Premier X12 does image 'ray tracing' rendering at a higher level. Cheers. Link to comment Share on other sites More sharing options...
