Shanks343 Posted January 18, 2021 Share Posted January 18, 2021 I'm sure this is an easy one: I'm trying to create a gable roof where the peak is off-set to one side, but the pitch is the same on both sides. I recognize that the wall on the side with the shorter span will have to be taller, but I can't figure out how to do it. Help? Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 Home Designer Suite 2021. Thanks for the advice about adding it to my signature. I've now done that Yes, I've been searching through HELP and the videos on YouTube. Lots of good info out there. Again, I'm sure the solution is simple. I just haven't found it yet Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 Roofs build over rooms, so you need to create rooms with different ceiling heights (ceiling height controls wall height). Any existing walls may be in the way, so suggest you remove them and just focus on the roof. Once it's perfect, turn off auto rebuild roofs, remove temporary walls and draw in what's really there. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 The section in question is over a single room, and I did try that: I put an invisible wall in the middle and changed the ceiling height of one of the rooms. What it did is illustrated in the attached screenshot: Instead of a single gable, it created one for each "room" at one end, but only that end. As you can see, the other end has the single gable, offset like I wanted. The specs on both walls is the same, so I'm not sure why it worked on one end and not the other. Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 This is what you want? Try turning off the roof on this side of the missing gable and see if it builds correctly. Is the remainder of the roof correct? You can attach the plan file (close Suite first) but someone will need to know what is correct. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 Yes, that is what I'm trying to achieve The rest of the roof is correct (I fixed the pitch of that center section so it now matches the others ... 6 in 12 instead of 8 in 12). Not sure how to "turn off the roof" on that side. Is something I do with the wall? Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 Just now, Shanks343 said: "turn off the roof" Rooms all have a Roof Over This Room setting on the Structure panel. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 OK, tried it. It just removed the roof Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 I was referring to the hip roofed section. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 Ah. OK, yeah that did it Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 That confirms your settings are correct, now to get Suite to not change them. Attach the plan file and someone will have a look. There a couple of people good at doing this and maybe they will have a look. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 Got it! I moved my invisible wall closer to the center of the structure, and for some reason it now builds correctly even with the other roof in place. Thanks for your help While I have you on the line: Any thoughts on how to make the red siding appear on the outside of those gable walls? They are technically interior walls, except, of course, parts of them are visible on the outside Link to comment Share on other sites More sharing options...
solver Posted January 18, 2021 Share Posted January 18, 2021 Change to an exterior wall, but you may see the exterior material on the inside, or cover them with an additional material. Thin soffit and or a shape from the library -- look for wedge. Link to comment Share on other sites More sharing options...
Shanks343 Posted January 18, 2021 Author Share Posted January 18, 2021 I'll give it a try. Thanks Link to comment Share on other sites More sharing options...
