GTboys Posted November 7, 2020 Share Posted November 7, 2020 Hi, I would like to create "rooms" (actually, areas) of different heights and connect them. My goal is that the roofline is also staggered in height. My problem is that the material on the wall that is shared between rooms does not appropriately change from interior (drywall) to exterior) siding above the roofline. I have created a simple example and am attaching images of the issue. In the example provided, the "exterior" wall is extended down into the room. I also tried changing the wall to an interior wall, but then I have a similar issue where the wall looks like an interior wall above the roofline. Any suggestions? Thank you in advance!!! Link to comment Share on other sites More sharing options...
solver Posted November 8, 2020 Share Posted November 8, 2020 Lower Wall Type When Split By Butting Roof Look in Help for info. Link to comment Share on other sites More sharing options...
GTboys Posted November 8, 2020 Author Share Posted November 8, 2020 Thank you! Link to comment Share on other sites More sharing options...
