JTinKC Posted September 14, 2020 Share Posted September 14, 2020 Does anyone know how to do this? I've been playing around with ceiling and roof beams, but I can't seem to make the beams round like a viga. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2020 Share Posted September 14, 2020 Try this symbol made and shared at Chief Talk some years ago: DJP Viga.calibz Link to comment Share on other sites More sharing options...
JTinKC Posted September 14, 2020 Author Share Posted September 14, 2020 That will definitely work. Thank you. Link to comment Share on other sites More sharing options...
JTinKC Posted September 14, 2020 Author Share Posted September 14, 2020 Strangely enough, when I look at from perspective view, the viga slants from about 2 feet off the floor to the position I tell it to sit on the other side of the room. Basically no matter where I set it, It's at a 40 degree angle across the room. What would cause one end not to be parallel with the floor or ceiling height I set? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2020 Share Posted September 14, 2020 In an elevation camera when you click-select the object do you not see a rotate handle??? I do. DJP Link to comment Share on other sites More sharing options...
JTinKC Posted September 14, 2020 Author Share Posted September 14, 2020 I can rotate it but it will only rotate in large chunks. It won't level out. Link to comment Share on other sites More sharing options...
JTinKC Posted September 14, 2020 Author Share Posted September 14, 2020 I think I figured it out by removing the snap. Link to comment Share on other sites More sharing options...
JTinKC Posted September 14, 2020 Author Share Posted September 14, 2020 What tool would I use to adjust the size of the viga, end to end? It's thicker on one end. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2020 Share Posted September 14, 2020 There are NO tools in Home Designer Pro for that adjustment, sorry. DJP Link to comment Share on other sites More sharing options...
