mels1949 Posted August 25, 2020 Share Posted August 25, 2020 As this is my first post, I am not sure what tags are. However, my question relates to the attached file. The house is being constructed using Thermocore 4" SIPS. However, the wall in the attachment directly above the text, 22', needs to be a 6 1/2" SIP. When I tried to change that one wall, all walls updated to the 6 1/2" thickness. Is it possible to change the one wall to a different thickness? Link to comment Share on other sites More sharing options...
solver Posted August 25, 2020 Share Posted August 25, 2020 15 minutes ago, mels1949 said: Is it possible to change the one wall to a different thickness? Yes. Open it and change the wall type. You may need to define a new wall type. Link to comment Share on other sites More sharing options...
mels1949 Posted August 25, 2020 Author Share Posted August 25, 2020 Eric, Thank You! Mel Link to comment Share on other sites More sharing options...
