loganjstuckey Posted August 15, 2020 Share Posted August 15, 2020 Can someone tell me how to make the wall be low fill in? I've tried several things but haven't had any luck. The ceiling above the patio is vaulted, but the one above the patio with the grill and table is a flat ceiling. Link to comment Share on other sites More sharing options...
solver Posted August 15, 2020 Share Posted August 15, 2020 22 minutes ago, loganjstuckey said: Can someone tell me how to make the wall be low fill in? Grab the wall to the left or right of the gap and pull it across to fill in. If you use Vector View for images like the one you posted, it makes it easier for others to see what's going on. Link to comment Share on other sites More sharing options...
loganjstuckey Posted August 15, 2020 Author Share Posted August 15, 2020 I did what you said, but the wall is showing in the vaulted ceiling in the other room now. I switched to vector as well. Link to comment Share on other sites More sharing options...
solver Posted August 15, 2020 Share Posted August 15, 2020 Read about Roof Cuts Wall At Bottom. Link to comment Share on other sites More sharing options...
