2_fins Posted June 21, 2020 Share Posted June 21, 2020 Using Home Designer Pro 2020 Have front exterior wall brick veneer with other exterior walls fiber cement boards. Want foundation to have brick outer layer and block inner layer. How may the front corners be modified so brick walls join? Thank you in advance for response Holly Lane Garage.plan Link to comment Share on other sites More sharing options...
solver Posted June 21, 2020 Share Posted June 21, 2020 I always seem to fumble around with foundation problems like this but see if this helps. Watch on YouTube: http://youtu.be/IyXkkP33-EQ?hd=1 Link to comment Share on other sites More sharing options...
solver Posted June 21, 2020 Share Posted June 21, 2020 I'm sure you have considered all possibilities. Link to comment Share on other sites More sharing options...
2_fins Posted June 22, 2020 Author Share Posted June 22, 2020 You are correct in your assumptions as to what I am trying to do. You solved my problem. Unfortunately, my Pro version does not seem to have the foundation tools contained in Chief Architect. This conceptional, non-finalized plan shows what I am trying to do for good views of canal and sound waters. Holly Lane Garage with House.plan Thank you Link to comment Share on other sites More sharing options...
solver Posted June 22, 2020 Share Posted June 22, 2020 16 minutes ago, 2_fins said: You solved my problem. Unfortunately, my Pro version does not seem to have the foundation tools contained in Chief Architect. I don't understand. I just used Pro 2020 to do what I did in Chief. Were you unable to do the same? Link to comment Share on other sites More sharing options...
2_fins Posted June 22, 2020 Author Share Posted June 22, 2020 My result flowing your excellent demonstration. Link to comment Share on other sites More sharing options...
