lopemanc Posted December 29, 2014 Share Posted December 29, 2014 I am new to HD Suites 2015 and have managed to produce a floor plan. The automatic dimessions seem fine. But I have some items located throughout the plan where I really want to add location Dimension lines. An example is a light location. I want to add dimmension lines from a wall to the lights center. Ever Dimension tool I try just draw a line and then dissapears on button release. I can draw dimensions between walls and they stay. Thanks for your help. Link to comment Share on other sites More sharing options...
solver Posted December 29, 2014 Share Posted December 29, 2014 CAD > Points > Place Point Place a point at the center of your light. Use the Point to Point Dimension tool to go from the point to a wall. You can then delete the temporary point if your wish. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 29, 2014 Share Posted December 29, 2014 you can also dimension to cad lines if Suite has the CAD OPTIONS ( not sure?) you may need to turn on dimensioning to electrical items in the defaults>Dimension>Dimensions settings , (see Pic) Link to comment Share on other sites More sharing options...
