Mitchilon Posted April 21, 2020 Share Posted April 21, 2020 Hello world I am new to HD. I have a completed home design that I have worked on for over a month. Now that it is complete I would like to reduce the size by 10 to 12 percent. Can this be done and how so? Thank you in advance. Example 1st floor is 5000 sq ft, 2nd floor is 2000 basement is 3000 finished living area. I would like for the first floor to be 4500 and every other floor change as a direct result of this change. HD pro version 2021 Link to comment Share on other sites More sharing options...
solver Posted April 21, 2020 Share Posted April 21, 2020 Nothing automatic. Change one floor, you are responsible for changing others. Link to comment Share on other sites More sharing options...
Mitchilon Posted April 21, 2020 Author Share Posted April 21, 2020 Can you reduce the size of one floor by 10 percent? Then I can redraw the basement and and 2nd floor within the walls of floor 1? 1 Link to comment Share on other sites More sharing options...
solver Posted April 21, 2020 Share Posted April 21, 2020 29 minutes ago, Mitchilon said: Can you reduce the size of one floor by 10 percent? You can move walls around however you like to reduce the size. Link to comment Share on other sites More sharing options...
