Changing the Top & Bottom Rail Profile
Resilient
Is it possible to change the profile of the top and/or bottom rail in Home Designer Pro 2020? I don't see that option anywhere in the railing specification. I would like to change the top rail on my railing to a square profile instead of the round one displayed in the image below. Thank you!!
I have updated my signature line to reflect the Home Designer Pro 2020. I have watched the "railing walls" video listed below. In the video, under the "railing defaults", there is a tab for "rails", where he is able to to change the top, bottom, and middle rail profiles. Is this possible in Home Designer Pro 2020? I noticed in the video that the narrator appears to be using Chief Architect Premier X6.
https://www.chiefarchitect.com/videos/watch/5230/railing-walls.html
That video is for Chief, not Home Designer.
I see no direct control over rail profile in Home Designer.
It looks like from your image above you are using Panels. If so, you may be able to build a railing in another program like SketchUp and import it for use as a railing panel.
