MNWaterWolf Posted January 30, 2020 Share Posted January 30, 2020 Hello, I'm new the the Home Designer Suite app. I'm just starting to finish the basement in my home and I'm wondering how I can represent the block half wall in my basement that is covered with an insulation pad. So far I've only been able to get 8ft tall block walls in my drawing. I've also got framed walls sitting on top of that block that our windows are built into etc... Link to comment Share on other sites More sharing options...
solver Posted January 30, 2020 Share Posted January 30, 2020 Posting a picture of your wall will help with suggestions. The more expensive titles -- Architectural and Pro have Pony Walls where the upper and lower parts of a wall may be different types like your block on the bottom, frame on top wall. With Suite you need to fake the look, often using a thin soffit applied to the wall. You can then paint the soffit with a material -- concrete block, for example to give the look of a concrete block wall. Link to comment Share on other sites More sharing options...
MNWaterWolf Posted January 30, 2020 Author Share Posted January 30, 2020 Thank you. I'll play around with it and see if I can get it to my liking. I'll get my signature set up as well. Dan Link to comment Share on other sites More sharing options...
