Fredo649 Posted January 26, 2020 Share Posted January 26, 2020 Is it possible to move the Label descriptions of objects such as Duplex Rec. or Smoke Det. closer to the actual object , mine seem to be to far from the actual object and interfere with other objects close by. I have looked but can't seem to find a way to move the label closer. Link to comment Share on other sites More sharing options...
Rookie65 Posted January 26, 2020 Share Posted January 26, 2020 The only way I have been able to do that is when opening up the item's label tab in the DBX is to either tap the space bar to move it horizontally or the enter key to move it down further. I suppose you could also set the item to not show the label and enter a text description at the size font you desire and place it manually? Link to comment Share on other sites More sharing options...
Fredo649 Posted January 26, 2020 Author Share Posted January 26, 2020 5 minutes ago, Rookie65 said: The only way I have been able to do that is when opening up the item's label tab in the DBX is to either tap the space bar to move it horizontally or the enter key to move it down further. I suppose you could also set the item to not show the label and enter a text description at the size font you desire and place it manually? Thanks , I may create my own text. as you say . Link to comment Share on other sites More sharing options...
