bfulford Posted January 11, 2020 Share Posted January 11, 2020 Just started learning Home Designer Pro but have immediately encountered a problem with interior wall dimensions not showing. On attached screenshot you can see that I have the exterior dimensions and have selected a wall but no interior dimension appears. Screenshot2 shows the dimension settings. Any suggestions on what's wrong? Link to comment Share on other sites More sharing options...
solver Posted January 11, 2020 Share Posted January 11, 2020 4 minutes ago, bfulford said: Any suggestions on what's wrong? Nothing is wrong. Try removing the exterior dimensions -- Edit>Delete Objects and see what happens. Link to comment Share on other sites More sharing options...
bfulford Posted January 12, 2020 Author Share Posted January 12, 2020 SOLVED My version doesn't seem to work as the tutorials describe, but I have found a good work around shown in the attached screenshot3. Manually add the required interior dimensions. Select a wall perpendicular to one of these which produces a pointing hand mouse pointer. Click on the interior dimension. A dialogue opens which allows the dimension to be changed. The trick is to change the dimensions in a clockwise direction. Link to comment Share on other sites More sharing options...
