emnm518 Posted January 7, 2020 Share Posted January 7, 2020 im trying to draw the front part of the house, particularly the brick portion on the picture below, I wanna draw the curved/sloped exterior wall, can anyone tell me what this design is so I can do some research on it or maybe guide me on how to make it using the software, im using Home Designer 2014, thanks in advance! Link to comment Share on other sites More sharing options...
solver Posted January 7, 2020 Share Posted January 7, 2020 The curved part is a Custom Backsplash. Draw it against the face of the wall, make it the same thickness as the wall, then move it left or right. Use Transform/Replicate to move it forward the thickness you just set. Shape as required. That should bet you started. Link to comment Share on other sites More sharing options...
emnm518 Posted January 7, 2020 Author Share Posted January 7, 2020 tried it but Home Designer 2014 doesnt have that feature Link to comment Share on other sites More sharing options...
solver Posted January 7, 2020 Share Posted January 7, 2020 Home Designer Pro does. You did not mention which title you have. If you have an older version of SketchUp, you could model the features and import. Link to comment Share on other sites More sharing options...
