UnSimpleFix Posted November 24, 2019 Share Posted November 24, 2019 Hello. I'm trying to make a staircase where the upper section of the staircase is enclosed with walls on both sides, but the bottom 4-6 stairs are open with balusters that go from the railing into treads that extend beyond the width of the walls, and the railings end in the short face of the walls: I drew standard interior walls that end where I want the enclosed part of the staircase to end, then I drew stairs wider than the walls with "open underneath" unchecked. The problem is the stairs cut off the walls all the way up the entire staircase. I've searched the KB and Q&A and didn't find anything, but I see in the first intro image in the KB for "Creating a Staircase", this exact thing appears to be shown, but it does not tell you how to cut the staircase with walls like this. I have Home Designer Pro 2020. Any help is appreciated. Thanks, Andrew Link to comment Share on other sites More sharing options...
solver Posted November 24, 2019 Share Posted November 24, 2019 Something like this? Link to comment Share on other sites More sharing options...
UnSimpleFix Posted November 24, 2019 Author Share Posted November 24, 2019 Hello Eric. Thank you for the reply. Yes, that appears to be it. How did you do it? Thanks, Andrew Link to comment Share on other sites More sharing options...
solver Posted November 24, 2019 Share Posted November 24, 2019 That's 2 stairs. You won't be able to do the handrails as shown, but I believe everything else is doable. Draw a single stair to get the dimensions/sizing correct, copy in place (now have 2 stairs in same place), lock the top and change the number of steps to make the upper part. Select the lower stair, lock the bottom and set the number of steps and change the width. This should get you close. Link to comment Share on other sites More sharing options...
UnSimpleFix Posted November 24, 2019 Author Share Posted November 24, 2019 Ahh ha. Thank you. I will try this right away. Link to comment Share on other sites More sharing options...
