charchID Posted November 20, 2014 Share Posted November 20, 2014 I am wondering whether the Home Designer Interiors software contains a skirting board object in its library. I am building a plan, and want to add skirting boards into it. Has anybody already done that with Home Designer Interiors? Where can I find that object? Any help would be appreciated thanks Link to comment Share on other sites More sharing options...
solver Posted November 21, 2014 Share Posted November 21, 2014 Is this for interior or exterior? A Soffit is often used to represent objects when you don't have other choices. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2014 Share Posted November 21, 2014 I don't have interiors but there are baseboards in the Core Library under architectural>Molding>Base Molding however depending on which template plan you choose to start your Plan/design with there is usually a base (skirting) and Casing (architrave) and in some a Crown (Scotia) automatically assigned to each room by default. ( and a wainscot/picture rail in some too) M. Link to comment Share on other sites More sharing options...
