DesignRescue Posted May 16, 2019 Share Posted May 16, 2019 I'm trying to create a 84" height ceiling in an open concept condo kitchen within the living space with a 96" ceiling. When I connect the invisible wall to the 3' end walls the drywall is stripped where the invisible wall meets it. Link to comment Share on other sites More sharing options...
DesignRescue Posted May 16, 2019 Author Share Posted May 16, 2019 Thanks Eric. Link to comment Share on other sites More sharing options...
DesignRescue Posted May 16, 2019 Author Share Posted May 16, 2019 Link to comment Share on other sites More sharing options...
DesignRescue Posted May 20, 2019 Author Share Posted May 20, 2019 I drew the walls, created 2 wall breaks, changed the wall type over the island to invisible. The ceiling height in the kitchen is dropped 7" lower than the adjacent living area, so I made the ceiling height 89" the ceiling height in living space is 96" I don't know why the drywall layer is not showing on the walls where the invisible wall starts???? Link to comment Share on other sites More sharing options...
Rookie65 Posted May 20, 2019 Share Posted May 20, 2019 Sometimes it's one of the little things that happen with the program. Could put a soffit at that intersection in the wall and have "use room mouldings" unchecked. That is one solution. Sometimes changing the wall framing material from studs to drywall could fix it too. Link to comment Share on other sites More sharing options...
