Alberto-Jauregui Posted November 16, 2014 Share Posted November 16, 2014 Is there an easy way to make a circular drive? I'm using Home Designer Pro 2015, any help will be greatly appreciated. Link to comment Share on other sites More sharing options...
solver Posted November 16, 2014 Share Posted November 16, 2014 Lots of helpful information http://www.homedesignersoftware.com/support/category/3/0/10/Home-Designer/ Look under Driveways. Also the Chief Architect YouTube channel https://www.youtube.com/user/ChiefArchitectInc/videos Link to comment Share on other sites More sharing options...
Kbird1 Posted November 16, 2014 Share Posted November 16, 2014 It is quite helpful when dealing with curves to use the CAD Tools, eg the Circle tool to draw a temporary circle, the right diameter and placing it where needed, the Driveway will the "snap" to the CAD Circle as you manipulate the Driveway Polyline (per tutorial above) , which should make it faster/easier, you can also use temporary CAD Lines to divide areas up evenly ( Cad lines can be dimensioned too) , eg dividing a circle into 1/4's , then you can delete them when done too. M. 1 Link to comment Share on other sites More sharing options...
Solution Alberto-Jauregui Posted November 17, 2014 Author Solution Share Posted November 17, 2014 Thank you so much Eric and Mick for your help I will give that a try. Link to comment Share on other sites More sharing options...
