DAR1960 Posted April 7, 2019 Share Posted April 7, 2019 These plans have show up a number of times. What is causing them? Sometimes I can close the file and reopen and they are gone. This time they are not going away. thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 7, 2019 Share Posted April 7, 2019 The software reacts to what you do and fail to do. Those unwanted wall artifacts could be caused by walls being out of alignment, floor to floor (solution: manually check all wall alignments and correct any found out of alignment). That is all I can suggest just from viewing a single image from a plan file. In order to say more, you need to share a copy of the plan for others to look at and study its settings and situations. Whatever it actually is, it is based upon something you did but not completed correctly or something you overlooked. DJP Link to comment Share on other sites More sharing options...
