Funky plans showing in orthographic views
DAR1960
The software reacts to what you do and fail to do. Those unwanted wall artifacts could be caused by walls being out of alignment, floor to floor (solution: manually check all wall alignments and correct any found out of alignment). That is all I can suggest just from viewing a single image from a plan file. In order to say more, you need to share a copy of the plan for others to look at and study its settings and situations. Whatever it actually is, it is based upon something you did but not completed correctly or something you overlooked.
