Grey X in Roof Design
Architectonic
Since your software, unlike Architectural, Suite. Essentials and Interiors has obviously a feature called "Points" which can be placed manually or automatically; ergo you must have Home Designer Pro.
The "Points" tools are found under the "CAD" menu - "Points". Open your Reference Manual (found under the "Help" menu and read the section in it about 'CAD Points" to educate your self on what they are and what uses they were designed for, please.
You may also find this Knowledge Base Help Article helpful as well:https://www.homedesignersoftware.com/support/article/KB-01113/toggling-the-display-of-roof-intersection-points.html
