BlackRock893 Posted March 15, 2019 Share Posted March 15, 2019 Hello, I have 2 buildings 24ft apart. I want to build a Bridge 11ft x 24ft between them. What is the best way to do this without changing roof for either of the existing Buildings ? I am below each Roof on each building . One is Hip Wall , the other is Gable end. I have attached rough plans Thanks Bear~North~Addition.plan Link to comment Share on other sites More sharing options...
solver Posted March 15, 2019 Share Posted March 15, 2019 3 minutes ago, BlackRock893 said: I want to build a Bridge 11ft x 24ft between them You will need to provide a picture or drawing of your proposed bridge and how it connects to both structures. Link to comment Share on other sites More sharing options...
BlackRock893 Posted March 15, 2019 Author Share Posted March 15, 2019 Architectural 2019. Sorry about that. The Bridge will be supported by Footings at each building and also at 12ft between Buildings. It will Be wood framed like a typical home exterior , room. I will be using I beams under for support. When I construct it, I create the ends as Gable but it changes the Right side building's roof by adding a Hip roof.....So I don't get much further. Thank you so much for any assistance as I learn this Software ! Link to comment Share on other sites More sharing options...
solver Posted March 15, 2019 Share Posted March 15, 2019 Your plan shows no bridge structure, and since the buildings are different colors, it will help to refer to them that way. Link to comment Share on other sites More sharing options...
BlackRock893 Posted March 15, 2019 Author Share Posted March 15, 2019 With Bridge Structure Rough. I have to learn how to raise the height of the Main House (blue) Walls as this is not accurate on the House side. The Barn (Red) is almost exactly as it will be built. My foundation is also much more exposed by grade than I show here. When I add walls to create this bride, the Red Barn ends up with a small wall rising up to peak of Red Barn. Thanks again Bear~North~Addition.plan Link to comment Share on other sites More sharing options...
solver Posted March 15, 2019 Share Posted March 15, 2019 It really helps if you post images of what you see. Windows has the Snipping Tool, Mac has similar. Here is what I see. What's wrong with this? Link to comment Share on other sites More sharing options...
