Transom Window above a Door
Hap-45
Transom window above a door displays in floor plan where just the door should display. Tried sending window to the back of the display group but that was no help. Searched Reference Manual, Help and Knowledge Base with no hits.
The attic wall was already there.
On level 1 > select window > Cut.
On level A > Paste Hold Position.
Elevation view shows it in the right place. Properties show it located relative to floor 1 same as before, so it seems a negative value is not needed, although it might be if I rebuild the walls.
Thanks!
