Room Perimeter Limits
Hap-45
I have made a garage with walls on a stem wall, interior slab 6" below top of stem wall. I added a roofed shed on the outside of the garage exterior wall, it has a slab floor 8" below the top of the stem wall. Before defining the floor elevation I turned off foundation auto-rebuild. The shed's defined space ends at the outside of the garage exterior wall. Problem is the shed's room definition is "removing" the foundation wall down to the bottom of the shed's slab floor. If I grip edit the bottom of the shed room limit upward the foundation wall follows along. It will follow along to any height, even above the defined top of stem wall. I need a way to tell the shed floor to stay outside the foundation wall.  File attached:  Barn-19-02-01.plan
