RSWallace Posted January 27, 2019 Share Posted January 27, 2019 Using Home Designer Architectural 2019. Trying to model pilasters on an existing house, so: a specific arrangement of fluted and plain "columns," bases, capitals, etc. If there were a catalog of pilasters, maybe I could find one close enough rather than build one, although that remains the ideal. Any suggestions how to proceed? Thanks, Scott Wallace Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 27, 2019 Share Posted January 27, 2019 I looked on the Home Designer website - Catalog downloads, you might try the "New England Classic" library, were there are wainscote panels you might be able to use to emulate pilasters. You can also try 3dwarehouse.com and do a search there for "pilasters". If you find something, you can then download it and then import that as a symbol into Architectural for use in your plan file. DJP Link to comment Share on other sites More sharing options...
RSWallace Posted January 27, 2019 Author Share Posted January 27, 2019 More helpful than I expected, thanks. My introduction to 3dwarehouse; found and downloaded a whole door assembly with pretty close pilasters (albeit with with an over-the-top [so to speak] pediment), but it's just an applique, not a working door. Also found a fluted column/capitol combo that's pretty close, which I think I'll experiment with. Thans again. Link to comment Share on other sites More sharing options...
