Copying objects between plans
NivRajan
HD PRO 2019 (MAC)
Hi,
I need to copy items from an older plan, to a newer modified plan, but can't seem to do so. Are there any workarounds for this, please? I've tried holding the Command button down, etc, but it doesn't move the item between plans (open in two tabbed windows).
Much obliged if someone could help urgently!
Thank you!
I do not often do this (I do not need to) but what worked for me is to have both plans open in the same Home Designer or Chief Architect application, then select-copy the target object in one plan (that copies the data of that object to the Windows Clipboard), then select the target plan file you want to place the intended object to. Then go to, in your Home Designer application to the "Edit" menu and select "Paste" to complete the transfer. The keyboard commands "CTRL - C" works to copy and then "CTRL-V" to paste.
