Change Default Exterior Wall Surface (HD Suite 2019)
BostonBassPlayer
I hope it's not a duplicate https://hometalk.chiefarchitect.com/topic/4760-exterior-wall-material/ but I can't figure it out
I want to change the default exterior wall surface. I can modify the surfaces one wall at at a time through the Material property of each wall, but I'd like to change them all at once, by changing the default. I just can't find the setting in "Default Settings". In "Default Settings/Walls" I can select wall types from a drop down list, but there is no way to edit these types. In "Default Settings/Materials", nothing shows up that seems to be related to the exterior wall surface.
Home Designer Suite 2019
