Inside to inside dimensions
studio
I have tried several other packages and have had the same problem and am curious if I would with HDP?  I flip houses, the house is already built and the sheetrock is up and finished, so I go in and measure the rooms with have inside to inside dimensions, none of the other package let you layout a room based on the inside to inside measurements.  Is it possible with HDP?  If so what do you have to change for it to function in this manner?
Thx
Please watch these Training Videos that address dimensions and dimension tools: https://www.homedesignersoftware.com/search/?default_tab=video&q=dimensions
Software does not, by itself DO anything, except what you guide it to do, so the better you understand how to control it to desired results the better. It is YOU, not the software that does or creates anything.
