JimAlsup Posted November 20, 2018 Share Posted November 20, 2018 Hello, Attached is a screen shot (capture.png) showing a foundation 3D view. Note how there looks to be a gap between the 4x8 joist and the plywood flooring. The floor structure is spec'd at 8" (7 1/4" and 3/4" plywood) so the plywood should sit directly on the 4x8 joist (3 1/2 x 7 1/4 actual). Screen shots of relevant dialogs and a simple .plan file are attached. Seems like I must be specing something wrong, but I don't see what. Any thoughts? Jim temp1.plan Link to comment Share on other sites More sharing options...
solver Posted November 20, 2018 Share Posted November 20, 2018 It's usually best to use a section view to check these things. Looks OK to me here. Link to comment Share on other sites More sharing options...
JimAlsup Posted November 20, 2018 Author Share Posted November 20, 2018 Eric, Hmm, thought I had a signature in place, but I now see they're different forums for the different products and for some reason separate profile data. I've attached a section view pic. The tape measure tool shows the space between the top of the joist and top of the floor (not including the interior flooring) to be 2". Should be 3/4". I did consult the online help on these dialogs, but came up empty. Jim Link to comment Share on other sites More sharing options...
solver Posted November 20, 2018 Share Posted November 20, 2018 It looks like you have manually placed a beam within the floor structure, and I'm guessing that's what you are looking at. The Tape Measure tool is often not the best tool to use when you want a precise measurement. See my image above showing actual measurements. The program is building the floor structure just as you instructed, using I-joist and using the beam you drew in. Do a Perspective Framing Overview to see. 9 hours ago, JimAlsup said: The floor structure is spec'd at 8" (7 1/4" and 3/4" plywood) so the plywood should sit directly on the 4x8 joist (3 1/2 x 7 1/4 actual). You need to tell the program to build the floor with the 4x8 lumber joist and you will get this. Link to comment Share on other sites More sharing options...
JimAlsup Posted November 20, 2018 Author Share Posted November 20, 2018 Hello Eric, Yes, you are correct. What I was missing was the sill plate. I just never saw that displayed and assumed HDP was just using the stem wall top as the plate. I found a display setting, enabled it, adjusted my girder/joist to land on it and everything is good. Note sure why HDP thinks that not displaying the sill plate by default is a good idea. Thank you, Jim Link to comment Share on other sites More sharing options...
