VRAinteriors Posted October 15, 2018 Share Posted October 15, 2018 I am new at Chief Architect and am drawing a floor plan. I am dimensioning interiors only so I am needing surface to surface dimensions for all walls. The double line that represents the finished wall is no longer there. The walls are only single lines. Not sure if I clicked something without realizing it but I need to see the finished surface off all walls to dimensions. Anyone run across the same issue? How can I fix this? I have included a Screen shot of what I am referring to. Thanks Link to comment Share on other sites More sharing options...
solver Posted October 15, 2018 Share Posted October 15, 2018 8 minutes ago, VRAinteriors said: I am new at Chief Architect Are you using Home Designer or Chief Architect? You probably checked Walls, Main Layer Only in your layer display options. Link to comment Share on other sites More sharing options...
VRAinteriors Posted October 15, 2018 Author Share Posted October 15, 2018 Thank you for your quick response. I am in Chief Architect. I was in the wrong layer set and qwas able to fix it. Link to comment Share on other sites More sharing options...
solver Posted October 15, 2018 Share Posted October 15, 2018 1 hour ago, VRAinteriors said: I am in Chief Architect. Then you belong at ChiefTalk. https://chieftalk.chiefarchitect.com/ Link to comment Share on other sites More sharing options...
