JoshMc Posted October 12, 2018 Share Posted October 12, 2018 Hello. I'm working on a plan to add a garage to our existing 1-level ranch. The main level floor is about 41" above the driveway, thus the garage floor will be about 41" lower than the main level floor. I'm trying to take advantage of this and stuff a bonus room above the new garage. On the front of the garage I've added a gable roof above the garage doors to keep snow from piling up in front of the doors, and also to add head room above the garage. On the rear of the new garage, I've added a dormer with a shed roof. I'm having a couple issues currently... the gable roof on the front of the garage is not high enough (pitch is too low), I want the ridge of the gable to meet the ridge of the main roof -- I can't edit the pitch since there is no hip roof wall here (I've split the wall) I want to remove the hip roof in front of the dormer, so I can add windows there (see cross-section) -- I've extended the eave of the dormer to match that of the main roof I realize my plan has a bunch of issues, please ignore, I'm working on it! I'd love some feedback regarding my 2 problems above, and any general feedback as well. Plan and screenshots attached. Also, I'm using Home Designer Suite 2019. Thanks! Evergreen.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 17, 2018 Share Posted October 17, 2018 1. If you do not want the roof eave showing below the dormer, then you can not use the dormer tool to place the shed dormer. Read up on dormers in the knowledge base. 2. The only way I can see to change the pitch of the garage front gable, is to extend the gable portion of the wall slightly outward, adding 2 side walls. The side walls allow you to change the pitch. Link to comment Share on other sites More sharing options...
