jproy1957 Posted October 24, 2014 Share Posted October 24, 2014 I have finished drawing my kitchen plans. I need to give a front view to my kitchen/cabinet builder. Kind of the equivalent to the top view but from the front with measures. A 3D camera view is not sufficient. The problem with the top view is that it is impossible to extract all information for base cabinet and wall cabinet by looking at that view on a printout. I am using the "Interiors 2015" version J.P. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 24, 2014 Share Posted October 24, 2014 Interiors does not have a wall elevation tool like Home Designer Pro does, so what I would do if all I had was Interiors would be to add Text annotations to the plan view where needed and then make image-renders of the cabinets using your camera tools adding text annotations using Microsoft Paint or similar image editing software as a substitute for the non-existant wall elevation type tool commonly used for kitchen design plans. DJP Link to comment Share on other sites More sharing options...
jproy1957 Posted October 24, 2014 Author Share Posted October 24, 2014 Thanx David. This is exactly what I needed. My simplest solution is probably to upgrade to the "Pro" version. Again thank you. J.P. Link to comment Share on other sites More sharing options...
