Dr_Drew Posted September 20, 2018 Share Posted September 20, 2018 My foundation is on a slopping lot. The basement rises about 2' above grade in the front and the rear of the basement is at ground level. The lot slopes away pretty much uniformly. The garage is ~2' below the main house and the family room on the other side is 1' below the main level. I just purchased Home Designer suite. Will I be able to represent those ground elevations? Thanks much Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 20, 2018 Share Posted September 20, 2018 Yes, these articles should help you in that cause: https://www.homedesignersoftware.com/search/?default_tab=support&q=sloping+terrain DJP Link to comment Share on other sites More sharing options...
