jnicbell321 Posted August 28, 2018 Share Posted August 28, 2018 What is the best way to add an arched soffit over a window and a soffit for a light in the ceiling. See photo. Thanks, Jen Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 28, 2018 Share Posted August 28, 2018 You draw a small room (space enclosed by walls), then place a doorway that you make into an "arch" by way of the doorways "Arch" tab in the Door Specification dialog for the doorway. to finish off you would add the pedestals using custom slabs that you apply a white material. To get the thickness shown in your photo you might use a custom thickened wall to get just the look you need and want. DJP Link to comment Share on other sites More sharing options...
