Installing deck around pool skp file
Pats359
I found the perfect pools skp file. It has an endless feature as part of the pool (meaning the feature looks like the water flows off the end). I have built my deck around the pool and have it even with the pool just under the tile. However, the endless part is also level and does not show the water falling over into the basin. Can I fix that? Thanking you in advance for any help you can give me.
In order for your .skp symbol to show properly, you will have to make a hole in the deck which surrounds the pool object and also cut a hole in the terrain (if you have created a terrain Plane). Since I cannot see your plan file, that is my advice for now.
