ProDesignNick Posted May 3, 2018 Share Posted May 3, 2018 The smallest dimension fraction is 1/16 by default. I changed it to 1/2 but it goes back to 1/16 when I restart the program. How do I get it to stay at 1/2? Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 3, 2018 Share Posted May 3, 2018 To change the way Dimensions display, you go to "Edit - Default Settings - Dimensions - Primary Format" to change the "Smallest Fraction" that dimensions then use. If you did not "Save" after changing the fraction value or you hit "Cancel" after making the change to Dimension Defaults, then the change did not "change". Thre is no other control available nor is any other control necessary. This software only does what you set it to do or fail to set it to do or just wrongly set it, the software is a direct reflection of your knowledge of and control of the software and its settings. Nothing else is possible. DJP Link to comment Share on other sites More sharing options...
ProDesignNick Posted May 4, 2018 Author Share Posted May 4, 2018 David, there is no "Save" per the attached. Nick Link to comment Share on other sites More sharing options...
