LPRemodel
Curved steps
I am drawing a deck that has an arc at the front. I need a single step up around both sides and the arc. The sides are no problem, however, I can't get a step to follow the arc at the front edge. Is there any way to do this? I can draw it 2D, but it won't show on the 3D camera shot. I am pretty new to this, running Home Designer Architectural 2019.
Untitled 3.plan
Use 2 slabs, one thinner than the other (one is the riser, the other is the tread) with the appropriate materials applied.  Change the front of the slab to an arc (both pieces). Raise the 'tread' to be above the 'riser'.
OR..you could do a second deck (pic) lower than the 1st.
