DavidAndrade
Need help resizing aggled walls
Solver or anyone who can help,
I am having issues with a pop out wall I'm working on.
I am designing a house that has a back wall that pops out at an angle. I don't know how to attach the screen shot so i took a photo.  Its like a large bow window, but the whole wall pops out floor to ceiling, it has 5 sections that are all equal. In the drawing I am unable to change the angle of the walls so they are all equal
I tried placing a bow window in the drawing but I am unable to resize the windows within the bow.
If you can help me resize the walls of the current drawing or resize the windows within the bow window that would work too.
Thank you
resizing walls Rama.pdf
Answers often depend on which title (Suite, Pro etc) and version (2018, 2019 etc) you are using.
You can help everyone by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
Place the bow window in the plan.
When you have resized it correctly, select it.
Then hit the 'tab' key.  Then hit 'Ctrl + e' and the window should open.  Changing it's attributes here, will change all 5 windows.
I tried this but it the program only gives the choice to have windows or not. it does not allow an option to resize the windows within the bow. Perhaps its because my version is so old. I'm using version 9
You are mistaken.
It works as I said, all the way back to Home Designer Suite 7.
I know this because I tried it.
11 hours ago, Jo_Ann said:
You are mistaken.
So you were able to resize the actual windows within the bow window while keeping the bow window the original size? I tried several times to change the window sizes while keeping the bow window the original size to no avail. I just cant seem to do it. I don't know how to show the dialog box but mine does not allow for window resizing, unless I'm missing something, which is highly likely. :0)
Maybe you should post a jpeg of the floor plan, showing the window and it's dimensions.
