Wall/Foundation issue
GLOBE-Res
I just tried this, and it worked.
Open a new plan, tiled vertically next to the Rieger plan.
Draw a short exterior wall (new plan), highlighted, then (on the TOP toolbar) choose edit / copy.
With the Rieger plan now the active plan /  top toolbar / paste.
The wall will be given a new name, because your version of siding 6 already exits.
Copy this wall, open the copy, then wall types tab, and give the wall a new name.  Edit all the fill colors to what you want.
Both the structurally correct original wall, AND the NEW wall should now show up under 'wall types'.
sorry, i couldn't pass that up
It dawned on my to create a template for my project types though.
I do a bunch of Home Addition projects.  The homes are either brick veneer or siding veneer.  So once I get my client to settle on a design I can go to CD's fairly quick.
The Final CD's are minimal information.  The Building Inspectors like them.  The builders like them.  There is a Cover sheet, Plan sheets, Elevation sheets, Detail Sheets, Wall Section sheets and a Set of Specifications that are taken right out of the IRC. Simple yet informative and accurate.  Very little to screw up
